F! Seat nut fell through!
Hey,
soooo I was putting my driver's seat back in and one of the nuts fell out of its spot into the floor.
What the F do I do to fix this one?
I almost forgot ( not that it matters) that it is a 1998 4runner
Same thing happened on my Ranger a while back. Drill the hole out and get a rivnut kit. You might need to use a larger size rivnut to be able to span that hole and a corresponding larger bolt to bolt the seat to the floor.
Which one.
Don't have a clear idea of which one that is or how it was attached. Could probably use a broader photo, and better description.
Front or rear? Inner or outer? What does the intact one on the other seat look like?
If it's a blind hole the rivet nut, or welding are your only options. If you have access to the backside you can use an array of fender washers to step down to the right bolt size.
Like so.
Like so.
I took a 3/8" bit and drilled through the floor pan, then installed a long 3/8" bolt, nut and fender washer. Slobber with RTV underneath and it's been good for the last four years.
Did the same as The Durk with like results.
Stack you up another set of nut and fender washer on the end of a long bolt. Weld or JB Weld nut to washer. Apply some form of glue or fast weld to the back of the washer/ nut set. Slide it in there sideways, pull it up in place and let it set up. Then carefully thread your seat bolt through it. Once it's threaded, you've got it. You may end up with another nut and washer in the pan but good chance you'll get it to thread and have a half way descent anchor.
Like so.
Like so.
If anybody takes their seat out, run a tap through those weld nuts before you put it back in and you may have better luck.
I have a '98 4runner and just had two of these occur. The passenger seat front right never has really fit in properly, bolt stripped out. While trying to put in replacement bolt "plunk". Then just 2 days ago when trying to reach in my back pocket to remove my wallet, the drivers seat left front bolt went "plunk" so now I have both front seats short a seat bolt. So my question is the picture of the nut, washer, washer setup, how did you get it in and take the picture as well? Was trying to think of how to get JB Weld on the nut. Did you cut a larger hole under the seat plate so as to get the nut/washer combo in place? Can anyone tell me what the size/thread is for the seat nuts so I can pick up a tap?
