ARB install
Old 03-20-2004, 02:44 PM
george16's Avatar
ARB air locker install
I just got done ordering my ARB air locker and compressor and I want to solicit all your inputs to make the install as painless as possible. Pretty much, I will be unbolting the 3rd member and taking it to 4wheel parts store here in Jacksonville, FL and have them install the locker. Questions that I have are the following:
1. Do I have to replace the carrier bearings?
2. Do I need to replace the axle seals after pulling the axles out for the removal of the 3rd member?
3. What type of gasket sealant do I have to use for reinstallation of the 3rd?
4. Any torque specs for the axle and 3rd member bolts?
5. Any other "secrets" to make the reinstallation of the 3rd memberand axles a breeze?
6. Are the carrier bearings the same for the 89-95 V6 and 96-02 4runners?
Any help is appreciated. Thanks.
George
Old 03-20-2004, 06:34 PM
NCSU-4runner's Avatar
probably not, your truck is only a couple years old, those should last alot longer than that
not if you are careful, just pull the shafts straight out and the seals will be fine
RTV - room temp vulcanizing rubber, comes in a tube from any auto store, run a small bead around the 3rd and re-install
not really sure, ive never used a torque wrentch any of the times ive replaced 3rds, just get the nuts on there good and tight and you'll be fine. torque specs are only usefull when really small or really high torque levels are needed
3rds are heavy mofos, if you can get a buddy to help remove it and lift it back in place that will help alot
no idea
my 0.02, its not extremely difficult, good luck
Old 03-20-2004, 06:38 PM
KING's Avatar
If it's not a secret, how much did the shop charge you to install the locker?
What did you spend total on everything?
Old 03-20-2004, 07:03 PM
george16's Avatar
ARB locker and compressor - $840 shipped plus $195 for the install.
NCSU - Thanks for all the inputs.
George
Old 03-20-2004, 07:05 PM
KING's Avatar
Did you put in new gears?
Old 03-20-2004, 07:10 PM
george16's Avatar
No, I will not. I'm keeping the stock 4.10. This mod is not done yet. I'm still waiting for the locker and compressor.
George
Old 03-20-2004, 07:12 PM
KING's Avatar
Pardon self, I had thought I read you had done the install. You have just ordered the locker.
Old 03-21-2004, 07:11 PM
anytime man, hope you enjoy the locker, its a night and day difference for sure
he's gone
7
12-03-2019 07:08 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
nick9455649
09-11-2015 05:10 PM
HaukurU
08-03-2015 02:40 PM
A2theK
07-12-2015 10:46 AM
Quick Reply: ARB install
