3rd gen. 3" body lift help??
Just need the dimensions of the shifter base, length, width, bolt hole spacing and location of the shifter pivot point. Below is the 3.0/V6 spacer plate, roughly square with slightly offset front and back bolt holes and the shifter pivoting in the center of that bolt pattern:
Or if measuring is too hard, then a tracing of the shifter base showing the bolt hole locations and shifter pivot point will work, or if you have a little down time, pull the shifter and send it to me to make up a spacer to fit.
there should be a plate that bolts the shifter down to the t case corrct? so if i take measurements off that you would be able to tell me if the 3.0 v6 kit works??
okay great i will get back to you thanks
quick question, what have you heard about this toytec spacer lift
http://toyteclifts.com/index.php?pag...mart&Itemid=53
i wont be on the trail to much
or maybe just fork out the cash for this one
but i guess if i were to spend the cash on the better one from toytec might as well go with sonoran full kit right?
06-01-2021 01:51 PM
09-04-2015 09:27 AM
anniesball
07-29-2015 11:46 AM
