285/75-R16 with stock suspension
Old 11-09-2009, 08:38 AM
brian2sun's Avatar
Originally Posted by 02_Limited
Woah, 305's on only 2.5" of lift? Kudos to you on that, didn't think 305's were possible with anything less than 3" of suspension lift and a body lift of some sort.
I am going back to 285s this next set. I wouldn't recommend 305s w/ 2.5" since mine do still rub a little (only when flexed out to the max) in the rear. It's only about .5" of the outside edge of the back tires that touch the edge of my fender when the tires stuff so 285s will just fit in there w/o making contact.
Old 11-09-2009, 03:35 PM
02_Limited's Avatar
Originally Posted by AlexJet
I put the lift first, then tires.
I do have some rubbing (very little) when backing up and turning wheel. It comes from the tip of the bumper which sits inside the fender well. I don't care much as it so little, so I can't see the rubbing signs on the bumper, just the corner itself and I'll be changing it anyway to ARB very soon.
Alex do you have any pictures of your 2001 after your lift and 285's?
Old 11-09-2009, 04:20 PM
AlexJet's Avatar
Here you go:
Old 11-09-2009, 04:25 PM
brian2sun's Avatar
That thing looks sweet Alex!
Old 11-09-2009, 04:29 PM
  #25
AlexJet's Avatar
This is my wife's truck. Soon it will be something like mine:
Old 11-09-2009, 04:51 PM
  #26
02_Limited's Avatar
Here you go:
Sick, thanks for the pic. How do you/your wife like the Toyo's? I'm stuck between those and the Nitto TG's
Old 11-09-2009, 05:59 PM
  #27
elmerfudd_22's Avatar
Just wondering how the toyec lift rides? I noticed compared to the soronan steel lift it doesnt come with brake line extensions, sway bar and e-brake adjustment pieces, panhard bar etc. I guess you dont need all of it to make this lift work?
Old 11-09-2009, 09:48 PM
  #28
brian2sun's Avatar
Wow!!
Old 11-09-2009, 10:23 PM
  #29
02_Limited's Avatar
Rides well and didn't need any of that other stuff to make it work. Once you get past 3" of lift in the rear you're more likely to need the panhard drop, extended brake lines, etc etc etc but 3" in front and back is the most common I'd say.
Old 11-10-2009, 12:21 PM
  #30
AlexJet's Avatar
Basically Toyo and Nitto are the same tires. We love the Toyo, in my opinion BEST tire on the market. On my 4Runner I have ProComp AT for winter (Extreme MT for summer )which are also very good, but Toyo in 35 is nearly double the price of ProComps, so I gone with ProComp. My wife rides 33 where Toyo is only 20% more expensive, so we went with Toyo.
Old 11-10-2009, 12:23 PM
  #31
AlexJet's Avatar
It rides great and didn't notice that I need an extra pieces. Time and experience will tell, but I think for not hard off-roading it should be good as it is.
Old 11-12-2009, 06:00 PM
  #32
and do you guys all have stock gears?
Old 11-15-2009, 09:53 PM
  #33
02_Limited's Avatar
Yup got stock gears, noticed a little bit of power loss with the 285's though. On hills
Old 11-15-2009, 10:03 PM
  #34
Elton's Avatar
stock gears but with a 5spd it ripps
Old 11-16-2009, 05:26 AM
  #35
fightman80's Avatar
This 4th Gen looks badass!!!
Old 11-16-2009, 09:55 AM
  #36
Elton's Avatar
you got one cool wife cause that 4th gen is no mall crawler
Old 11-17-2009, 03:14 PM
  #37
and how about gas milage?
Old 11-17-2009, 04:46 PM
  #38
AlexJet's Avatar
2005 with 1500lb of additional weight and everything you see 18l/100km city and 15l/100km highway.
2001 ~16-17 l/100km city now...
Old 11-17-2009, 07:50 PM
  #39
Kerby J's Avatar
hey i was wondering where you got ur decal of the increased tire size increases center of gravity and can cause rollover on yer 4th gen
Old 11-18-2009, 01:56 AM
  #40
AlexJet's Avatar
If you'rerefering to the greay leaning car - this is Total Chaos official Logo. I have front suspension build based on TC Long-Travel.
Quick Reply: 285/75-R16 with stock suspension
