2001 3rzfe won't restart after running for 1-2 minutes
Old 05-19-2019, 04:10 PM
ricky's Avatar
I've got this 2001 Tacoma that I love to death. Almost 250k miles. Second one I've had. Runs like a champ. Only issue is if I start it, let it run for a minute or so, then shut it off, it will not restart unless I wait 3 or 4 minutes. I can tell it's flooded because I've always noticed it does smell like it's running very rich on cold starts. If I give it a few minutes it'll eventually start. I replaced the upstream O2 sensor when I bought it about a year and a half ago because it would not pass emissions. No check engine lights. And no other issues with the engine. My old 95 sig Tacoma never had this issue. Any idea what would cause this?
Old 06-01-2019, 06:25 PM
75w90mantraN's Avatar
I would check batt charge. Check and clean batt posts, wiring and grounds for dirt or corrosion interference. If click, no start, check starter contacts. And see how plugs look to get more clues.
Check that the CEL turns on briefly at key on to rule out burned bulb.
pitbull_myk
11-25-2021 09:18 AM
spurlockda
02-12-2014 12:54 AM
Mr.Black
04-22-2013 08:07 AM
MHST Guy
11-22-2010 02:28 PM
Quick Reply: 2001 3rzfe won't restart after running for 1-2 minutes
