LGcrawler's 90 singlecab build-up thread
#84
#86
#87
#89
#90
The yota started idling high and when you put On the brake it will drop from like 1500 rpm to 800 then back up and down up and down until I let off the brake and it will idle at 1500 again. I replaced the TPS and it still did it. I cranked the idle down by using the screw on the throttle body but it just runs too rich and the check engine light came on, any suggestions?
#93
Sweet looking rig man, love the front tubing bumper. Thinking about making myself one. Where did you get your front spacers at? Might have missed it, but I saw that they were 1.5" big, did you crank your torsion bars too?
Let me know if you find out your idling issue! Mine has been acting up with the same exact problems, driving me crazy..
#94
Thanks man ya it has 1.5" 4crawler ball joint spacers, I didn't crank the torsion bars. The fiberglass is what makes it look like alot of lift up front. Hopefully I figure this idle issue out soon. I need to smog this beast
#96
#97
#98
alright ill give that a try, im thinking it also might be the coolant sensor. thanks for the advice
joeynational
09-05-2015 01:54 PM
86 87 4Runners
09-05-2015 06:02 AM
86 87 4Runners
09-02-2015 03:54 AM
