algranger's 1984 Pickup Build-Up Thread
#241
I was thinking about that if I can find some close to the length that I need hopefully longer would be great. I can cut it at home to the length I need if I find the right pieces. I just don't have a welder nor have I ever welded.
#242
Oh yeah i can weld for you. I have a 110 flux cored wire feed but it gets the job dont i've welded most everything on my truck with it.
Just let me know when you want some welding done or wanna meet up for a beer
#243
Well i've been adding a lot of those little things nothing real major lately
Added some runners since i kept hanging up on rocks
Flex-A-Lite on a toggle switch
Started to set up the OBA
New Cobra Digital CB (the old one was a pos)
V-6 4runner master cylinder
New quarter panels (the new ones are trashed already)
Clevis mounts and mudflap mounts
Doorless
Got 'er a little dirty
Doorless
#246
My steering fell off
Histeer time
Clearance test
Got some shackles from BigBluePile (thanks man!) and 15 minutes later:
Gonna try and clear 38's now wish me luck... i'm gonna need it
Histeer time
Clearance test
#249
I saw the pics, looks like a hell of a time.
#250
Well my snorkel was driving me crazy so i rerouted it up under the dash.... i hope its not too low...
Nice and clear around there
Also put some time into repairing a rust hole
#254
I havent done anything about the pinion angle yet, one of these days i will quit being lazy and set up new perches or at least burn on shims
#255
1 Post
I finally got my driveshaft back in (just got it lengthened) and the Ujoint is binding, but only when the grease nipple is at the top... I could probably just clearance it with a small dremmel or something like that, but I cant imagine it at full droop.
What length were your shackles for the front spring?
I have the Sky MFG boomerangs, I think the're 5.5", that may be why my pinion is pretty much flat
#256
Yeah i just did my rear driveshaft the other day now i'm all good to go there.
Thats strange that your binding... mine are smooth as butter and i have 2 extra leafs in the pack plus the overloads (maybe an extra inch of lift) then another inch or so from the front hanger and 5" Downey spring shackles. Maybe the perches were different in 83 or something idk.
06-01-2021 01:51 PM
