FS[GreatLakes]: [MI] 1987 SR5 4x4 22RE MT xtra cab with Aftermarket Box
#44
The vents sell pretty well, so since I pulled them before and were staring at me while in the house, they either sold to the person asking for them, or I popped them on ebay to get them moved. I might have more but I've sold most or all I have. I'll have to take a drive out to one of the last trucks I got to see if it has the vents yet or not. The year and style style does determine what fits what, 86 and older should be a thin dash pad which has the long pocket, 87 and up should be a thick dash pad with the short rectangle style pocket. The far left vent did change slightly too at that year change over. I'm not 100% sure if the dash pad change is exactly on the model year or not, as a whole group, the dash pad, ac vents, and the cluster cover can be interchanged as far as I know.
If I run across some of the vents, I'll shoot you a PM, but I'm kind of expecting them to be all gone by now.
#46
If you can get me good photos of each of the connectors you need replaced, I might be able to source all new connectors. I make ATV harnesses as my primary income so that's right along the lines of what I do. I should have some hacked up harnesses from misc machines, but most/all of the 22r/re harnesses I sold with the engines. I do have one 87 truck out back with a hacked up harness that I could pull plugs from too. If going with new pig tails I might not be able to find the connector housings new, but sometimes I can get new wire/terminals for them.
Jerome Horowitz
11
10-15-2014 12:33 PM
celica-fiend
08-31-2013 03:35 PM
Latigo
12
08-30-2013 10:51 PM
