WTB Ring and Pinion 4.30 or 4.56 4 cyl or V-6
Im looking for an OEM or aftermarket ring and pinion(new or used) for a 8" 4 cyl or v6 3rd member in a 4.30 ratio or 4.56 ratio. This is for our 2wd off road truck. It has 4.10 right now(31 inch tires) and it needs a little more power in 3rd and 4th gear(4 speed tranny) so let me know what ya got.
Heres a couple 3rds with gears in your area
http://sandiego.craigslist.org/esd/pts/641910081.html
4.56's
http://sandiego.craigslist.org/csd/pts/641216007.html
4.56's
I called the guy with the 3rd member and he said he sold is days ago but he relisted after he said he sold it?? Ill try the other guy. Shipping would be a lot for a complete third and im really only looking for the ring and pinion ive got 2 v-6 housings and a 4 cyl housing. Anyone know if a 4cyl spool would fit in a v-6 housing? yukon has two different spools for 4cyl and v-6. I thought when you have an entire carrier you can swap bearings on the end and make it work in either diffs?
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
