5VZ '97 engine, harness, ecu - 3.4l
'97 3.4l (5vz) engine with engine harness and ecu. It has an estimated ~140k on it. Timing belt was done at 94k. Would rather not ship, but if it doesn't move I may consider it. $800. I got this thinking I was going to do another conversion, but I decided that I was kidding myself.
Here's more detail:
I don't have all the vitals since I received it as part of a package deal with a '95 4Runner that had a rod knock. The '95 is just going to end up with a rebuilt 3.0 instead of a conversion.
Basically what I know so far is that it looks clean, the t-belt was changed at 95,667 on 2/17/2004 using a Toyota belt, probably done at a dealer. It is out of a 1997 4Runner (not sure if it was a Limited or SR5, but shouldn't be of consequence) and had an automatic behind it. There is no evidence of oil sludging. My estimate is that it has 136K on it, but I'm estimating that it's been out of the vehicle for the last year. Then I take the average mileage (13,666/yr) for the first 7 years and multiply it by ten. Not the most scientific, but it's probably close.
Includes:
everything from the throttle body to the oil pan
from the fan back to the flywheel/flexplate bolts
exhaust manifolds
crossover pipe
motor mounts
accessory mounts (p/s, alt, a/c)
coils/plug wires
engine harness 82121-3D400
ECU 89661-3D321 (mfg date 97.1.27) 5VZ 4X4 A/T
Does not include:
flywheel or flexplate
accessories (p/s pump, a/c comp., alt, starter)
Possible trades: A 3.4l 2nd gen supercharger? SAS parts for my '93 4runner? A high pinion e-locker w/4.88's to run in a '85 toy front axle? An early ('86-'95) IFS front axle with 4.88's and an ARB? Would consider interesting trades.
Includes:
exhaust manifolds
crossover pipe
motor mounts
coils/plug wires
Does not include:
Last edited by aLostDawg; 01-22-2008 at 11:01 AM. Reason: clarify trans & which IFS axle
Giving up?
I did tell my wife, jokingly, that if it didn't sell I'd put it on the go-cart project my son and I are building. That's probably a little overkill though.
Yeah the roads were interesting! Getting it back outta Julie's truck and into our garage was even more fun since the engine hoist we had wasn't pumping up properly. But we managed and got to bed around 2:00 am!
So now I have a My very own 500 LB hunk of metal and plastic paperweight sitting in my garage LOL...
Avenged
07-09-2015 07:55 AM
