1990 Toyota 4Runner V6 5sd. 4WD forsale
FOR SALE:
90 Toyota 4Runner V6 5spd. 4WD. Solid body with minor rust in front of rear wheels, nice interior with no rips and some carpet stains. Rear window works great. Freshly rebuilt engine with NEW: timing belt, all new timing belt tensioners and pulley, oil pump, water pump, thermostat, timing belt tensioner spring, coolant hoses, knock sensor harness (runs between cylinder head and lower intake), all new gaskets, seals, bearings, pistons, rings, valve seals, clutch, machined flywheel, rebuilt shifter, dist. cap, rotor, plugs, and wires. Motor runs good and is reliable with over 6000 miles on it since rebuild. New ball joints, tierod ends, pitman arm, idler arm, adjuster sleeves, Skyjacker steering stabilizer, new front brake rotors and pads, repacked front wheel bearings, new rear Moog coil springs, and Monroe shocks replaced over 10,000 miles ago. 31x10.50-15 tires on American Racing aluminum wheels.
This truck is stock height and does excellent off road and wont get stuck, it has been my daily driver and has never given me any problems.
Over $3,500 invested but will sell for $2,800 FIRM PM me if you have any offers or want pictures
PRICE HAS JUST BEEN REDUCED 7/4/08!, reasons for price reduction are as follows:
-Code for Knock sensor (sensor wire was replaced during rebuild, actual sensor now needs to be replaced)
-Power steering box input shaft seal leaks.
-Valve cover gaskets are seeping oil (new gaskets were put on when motor was rebuilt, but it seems they have failed)
FOR PICTURES GO HERE: http://norfolk.craigslist.org/car/688722745.html
Truck still runs and drives great!
Need this to sell. The price is more than fair. Reliable DD and reliable beach truck. Gas mileage is decent. Now over 5000 miles on motor since rebuild and no problems. Only thing is, the steering box input seal is leaking but can be easily fixed.
I'll trade you for a 86 4runner 2 door 4x4 5spd. 4cyl. EFI. Its got some issues with the sun roof leaking,and bad donuts in exhaust. Lifted and sitting on 33's, beside that all original and only has 124,000 miles on it.
There has got to be someone out there that wants it with cash in hand.
Big Little Bear
230
11-13-2023 11:42 AM
kawazx636
10-06-2021 03:03 PM
icentropy
09-10-2015 05:03 AM
