Domestic Swaps Chevrolet, Ford, ect
3.8 S/C swap in a 94 yota pickup
Old 12-22-2014, 07:12 PM
trd4runner's Avatar
Ok so im going to call it! I (as far as I know) am the first to complete the 3.8 S/C motor swap in this gen yota. I will do the best I can to explain what and how I did it.
[img][/img]
[img][/img]
Old 12-22-2014, 07:25 PM
trd4runner's Avatar
Im in the process of getting all the loose ends taken care of but hey you have to start some where.
Old 12-22-2014, 09:21 PM
totally a bro
Staff
vital22re's Avatar
bring on the details bro!
Old 12-23-2014, 07:22 PM
trd4runner's Avatar
Ok I have a bunch of pics on photobucket but im only able to post the small pics. Please tell me what im doing wrong.
Old 12-26-2014, 12:15 PM
trd4runner's Avatar
http://i87.photobucket.com/albums/k1...IMG_7169-1.jpg
Here is the link to my photobucket page. Im doing something wrong when trying to post pics. take a look and have fun with the pics
Old 01-02-2015, 12:48 PM
trd4runner's Avatar
Ok so one of the first parts you will need to find is a bell housing from a 97 dodge Dakota 4banger 2.5 with a AX15 5 speed. Don't forget the clutch fork. bolts from the housing to the gear box and the through out bearing and the front cover from the AX15. There will have to be milling to the bell housing. This comes from kiwipushrod on pirate4x4.com. take .250'' off the motor side and .120 off the gearbox side. While your at the machine shop get your input shaft milled down to the I.D. of a GM pilot from a 01 3.8 fire chicken and have them make the pilot bearing longer @ 3/16 . Input shaft is from allstargear.com part # AX15-16A 10 tooth. Now to the flywheel, get one from a 01 3.8 fire chicken. THERE is a difference in balance from N/A to S/C rotating assembly, what you should do is take both flywheel and flex plate to get balanced and have them take the N/A flywheel balanced to the S/C flex plate spec.
Old 01-02-2015, 03:11 PM
trd4runner's Avatar
[IMG][/IMG]
Old 01-02-2015, 03:16 PM
trd4runner's Avatar
[IMG][/IMG]
You will have to cut out for the starter
Old 01-02-2015, 03:17 PM
trd4runner's Avatar
[img][/img]
Old 01-02-2015, 03:27 PM
trd4runner's Avatar
[img][/img]
This is why you will need tot get the pilot bearing made longer. Also I forgot to say you MUST get the cover plate from at AX15 trans. ( the part where the throw-out bearing rides on)
Old 01-02-2015, 04:01 PM
trd4runner's Avatar
Now to install the input shaft from the AX15 into the R150 trans
[img][/img]
Remove the bolt that holds shift selector
[img][/img]
Next remove the alen or torks head on the side that hold a spring and ball in it. Tap the rear section off
[img][/img]
Old 01-02-2015, 04:02 PM
Rowdydudeman's Avatar
the 3800 is a fantastic motor with tons of potential. once those things are woken up from their stock form... MAN do they move. Have you though about upgrading that m90 to a tvs 2300?
Old 01-02-2015, 04:04 PM
trd4runner's Avatar
Remove the cover from the R150 where the thought out bearing rides on, 2 big snap rings hold the big bearings in place, remove snap rings tap the front section off.
[img][/img]
Old 01-02-2015, 04:10 PM
trd4runner's Avatar
[img][/img]
Place trams in vice
[img][/img]
Old 01-02-2015, 04:43 PM
trd4runner's Avatar
Cut the spline section off if you don't have a puller big enough. COVER all the rest of the trans when cutting!!!!!
[img][/img]
[img][/img]
Old 01-02-2015, 04:58 PM
trd4runner's Avatar
Once removed do the reverse process to put the old bearing on the new input shaft. BE CARFUL not to damage the dust covers
[img][/img]
Old 01-02-2015, 05:15 PM
trd4runner's Avatar
For what im looking for I wont need to upgrade the charger unless I gain some awesome results in the efficiency. Im guessing the way im set up now I should be @ 285HP close to 300 FT. Im trying to set this truck up for expedition style camping.
Old 01-02-2015, 05:41 PM
trd4runner's Avatar
Now to get this all together
Remove the big nut with an impact.
[img][/img]
PLACE in order and be carful!!!
[img][/img]
[img][/img]
[img][/img]
Now the input shaft can be removed!! I bet you where thinking how the hell does this come out.
reverse the steps to re assemble
Old 01-02-2015, 05:49 PM
That is exactly what it will do for you. The thing that kills the m90 and blowers like it is their lack of efficiency. They have 3 lobes where as the TVS style blowers have 4, they move the same amount of air (if not more) but can do so at a lower RPM thereby reducing parasitic loss and heat that will be generated. I did a very similar swap on my saturn (went from the m62 to a tvs 1320) and noticed huge gains in efficiency and lower iat2's.
Old 01-02-2015, 05:55 PM
trd4runner's Avatar
[img][/img]
Quick Reply: 3.8 S/C swap in a 94 yota pickup
