22re to 7mge need some help
Well im getting very close to doing this swap! Have read a alot on it and been throwing ideas around in my head! One thing that I need to find more info on is cooling! What radiator should I use? I was thinking the supra or toyota 3.0 radiator and (2) electric fans! If any body has any ideas let me know!
No one has said anything on the 2 connectors that go to the transmission on a 94 toyota pickup. Im thinking about just pulling apart my 22re wire harness and reusing these wires. Does anyone see a problem with that?
see my truck also dosent have a cable speed O. So Im thinking just reusing these connectors and just leave them the way they were! what you think motorhead?
#25
I still cant figure out what wire I need to tie into my starter signal to tell the ecu im starting the engine. I have wire diagrams and everthing. If some one could point me in the right direction that would be sweet~!
#27
I'm pretty sure that it's already done for you...look in the harness between the firewall and the engine, find the small black/blue and it should trace to the large one before it reaches the rubber plug at the firewall. On a side note, I ended up using the black/white ground in the plug under the hood that carries the black/yellow you use to go to battery power. Needed it to make my cel stuff work...why, I have no idea, doesn't sound like anyone else did/does.
#28
Yeah i figured it out yesterday after looking at the wire diagrams and testing stuff out. I have one question, how come my oil light and other light dont come on when Im fisrt starting the engine and then go off after the key has been on a while? I hooked up all the wire for guages and the guages work but the lights dont come on. I also grounded the same wire you did, thats what the wire diagram says that wire if for.
