Toyota Motorhome 3.0 Swap
#81
I finally got the hood back with good news and bad news: they did a good job on the sculpting and fill work but a terrible job on the paint color. I'm getting too old to fight with them, so I took the hood, and now I'll get the entire cab painted! I think I'll start on the SC in December. Anyone hear of any good deals on this unit? http://photobucket.com/motorhomeengineswap
#83
Alternator Bracket: I didn't cut anything down, but I did some bending. I'll post a pic that should make it clear.
I paid $650 for the wiring--money well spent.
#84
#86
I'm doing the last little bit on the engine now! Hope to be pulling the 3.0L in January
Thanks!
Andrew.
#89
#90
Andrew,
The upper hose is Dayco C71765
Lower hose is Dayco C71620
I didn't have to cut anything--perfect fit
I'll get the number of the alt. belt a little later. I have someone working on the RV ac right now.
#91
Thank you Captainjack! I will be ordering those hoses...
I have heard that you can use the 3.0L lower alternator adjustment bracket, then you can use Napa micro-v belt # 25-040405
You used the 3.4L adjustment bracket, just made it shorter. Did you just cut and then re-bend the end? (Engine block side)
Thanks again !!!
Andrew.
Thanks again !!!
Andrew.
DacodaYota
09-02-2015 02:13 PM
