3.4 swap begins
also i have elvot's thread bookmarked.
For me to have a CEL, I'd actually have to have the light wired
Never got around to that part of the swap.
Been running fine for almost 3 years (August 20th-ish 2007) with over 114 500 kms (71,500 miles) on it, and no problems.
#25
put the new timing belt, water pump, thermostat on last night. tonight going to work on finishing the wiring and welding up the rad support and front frame sections (cracks and separation from over time of driving mainly dirt roads).
#27
doing the oil pan/ pickup/dipstick/rear main/oil pressure gauge sender now.
for the alt lower bracket i used the factory 3.0 one. then for my oil pressure sending unit i used a 90 deg brass elbow then screwed it on so that it would not interfere with the alt bracket.
wiring is mostly done with exception for the small stuff, road lights, e-fan, dash switches, etc...
hopefully it starts up and runs good. down to 6 nights to finish before we need the truck for bear season (with hounds) here.
#28
well down to 2 days left. motor is in and runs. need to do exh, put bed on, hood scoop, and other small things. but SHE IS ALIVE!!
time for sleep. i will post up more picts when i have some time.
for the power steering pressure hose i did use the tacoma one. i have a small hand held tubing bender and just straightened and rebent.
#32
the idle went down, i had the heater core closed and got a air bubble. idle is great now and has tons of power.
more picts to come
more picts to come
#34
Lion hunt?? In Arizona? Or is a "Lion hunt" something other than what I am thinking it is? What does your oil pressure gauge read after it has warmed up??
P.S. She is looking great!!!
#35
yea mountain lion (bear hunting with dogs here in az is only in the fall). cant remember what the oil pressure reads when it is at operating temp but i will try to remember to make a mental note of it and re-post it later.
#37
sorry been awhile. using the 94 gauges and 3.0 sending unit on the 3.4 block the gauge warmed up idling reads between the low and first slack mark.
Flying91
45
04-11-2024 04:39 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
