BG 44K into intake??
Old 05-26-2004, 07:34 AM
humanoid's Avatar
I was perusing the 4x4wire.com board and came across a thread where some guy did sort of the SeaFoam thing, but with a can of BG 44K through the intake and it worked quite well. Anyhoo, any of you folks tried this yet and any consequences of this?
http://www.4x4wire.com/forums/showfl...t=1#Post527961
humanoid is offline
Old 05-26-2004, 10:46 AM
humanoid's Avatar
bump for any observations on this topic?
humanoid is offline
Old 05-26-2004, 02:54 PM
Mohamed's Avatar
That "guy" is me
I posted what my experience was with seafoam on this board, in this thread. I still wouldn't eject into my intake, that would kinda scare me to do that, you really could snap a connecting rod when you hydrolock the car. besides seafoam is only $6.99 @ Napa, and BG 44k I got for like $20 something a can.
Mohamed is offline
Old 05-26-2004, 07:24 PM
Nic
Nic's Avatar
I've wondered about doing the same with BG 44K instead. I thought of this after reading Mohamed's post on the Seafoam. I would like to try it on my 84 Camry to see if it would help it run even better. I used a can of the BG 44K in the tank and it idles much better, but I would like to run some cleaner through the brake booster line like Mohamed and see if it would help some more.
If I do it, I will probably just get a can of the Seafoam since it is about $6.00 here and save my two cans of pricey BG 44K for the gas tank.
Nic is offline
kawazx636
10-06-2021 03:03 PM
LittleUgly
15
01-02-2020 01:30 PM
wberry85
05-17-2016 05:45 PM
alexcarey
10-14-2015 06:05 PM
mreagen
10-05-2015 04:27 PM
Quick Reply: BG 44K into intake??
