Engine Swaps Swapping an engine in your Toy, here is where to learn how
Head Gasket
Old 12-28-2011, 12:22 PM
Fire Fighter 431's Avatar
Head Gasket
I was wondering i have a 95 Toyota pickup mint condition and the head gasket blew on it should i replace it or put a different motor in it thanks Ryan
Old 12-28-2011, 12:23 PM
Swimmerboy2112's Avatar
Look into the 3.4L 5VZFE swap.
Old 12-28-2011, 12:24 PM
22repower's Avatar
4cyl or v6?
Old 12-28-2011, 03:24 PM
cziemer's Avatar
If you got the 3.0 I'll just say that I blew my HG over the weekend and using part store parts (gotta have it buttoned up by Monday) I spent about $400 on the gaskets, new head bolts, a new timing belt and water pump (no idea when they were changed last). Not counting oil, antifreeze, and any other things that might be bad when I tear into it tomorrow, from what I've been reading that's easily 1/3 of the way into a 3.4L swap, which nets you a more powerful and reliable engine. If I wasn't on such a short time frame myself I would have definitely gone the way of the 3.4.
Old 12-28-2011, 03:46 PM
peow130's Avatar
Buy a felpro top end gasket kit, new oil, new coolant, fix it and run it.
Old 12-29-2011, 11:39 AM
v6 automatic how would i go about doing this engine swap ?
Old 12-29-2011, 12:50 PM
93toyrunner2's Avatar
Assuming you have a 3VZE, you would need to locate a 5VZE motor, complete engine wiring harness, and ECU (computer). Pull out your old motor, remove the wiring harness and the computer from the passenger side interior kick panel, reinstall in reverse order. There are quite a few write ups on this website with detailed swaps. Use the Search button above, and grab a cold drink..
Old 12-29-2011, 07:34 PM
Thanks for the advice could someone give me a ball park estimate on the total cost on doing this thanks !
Old 12-30-2011, 05:47 PM
eric924run's Avatar
I found a company that sells the 3.4 ready to go for 3500.00 shipped to you. it is set up for the ps and ac and alternator to bolt right up. if you have an auto i think it was a little more. if your doing it your self figure another 1000.00 for all the other little stuff like exhaust, ect. if you have to pay for labor then probaly around 6k total.
Old 12-30-2011, 05:57 PM
rattlewagon's Avatar
Agreed.
My first headgasket took me about 15 hours. Good Luck!
You can get the gasket set from rock auto for about 1/2 of what youll get it for in the parts stores.
Old 12-30-2011, 07:57 PM
Can you give me the link for the web site that sells thos motors thanks.
Old 12-30-2011, 08:06 PM
eric924run's Avatar
sent you a pm
Old 12-30-2011, 08:09 PM
fork's Avatar
just make sure to use the toyota head gasket.
Old 01-02-2012, 05:00 PM
Anyone know anhthing about a 350 swap ?
Old 01-02-2012, 05:29 PM
peow130's Avatar
You can spend a few thou doing any other motor swap, or you can fix your junk for under 500 dollars.
Are you trying to spend a grand or two?
Old 01-02-2012, 05:40 PM
I can spend some money
Old 01-06-2012, 12:01 PM
Motor swap
I have a 95 pickup with v6 3.0 and head gasket went bad on it. A few good shops where i live gave me a est. of about 1700 to do the head gasket, timing, and water pump but with that being said im thinking about mabey going about putting a 350 and doing the whole deal i have a shop to work at plus i can get a deal on part no a guy that ownes a junk yard any suggestions thanks Ryan.
Old 01-06-2012, 12:04 PM
abecedarian's Avatar
http://www.northwestoffroad.com/parts/engineswap.php
http://www.advanceadapters.com/
Old 01-06-2012, 01:57 PM
drmix's Avatar
Keep it Toyota get a 3.4 or the Lexus V8.
I hate when people take a good dependable truck and swap out the motor for an American motor.
Whats the point of getting a Toyota truck to swap out for a 350? Why not just buy an American truck to start out with?
Old 01-06-2012, 02:03 PM
FattMaanLittleTruck's Avatar
350 swap is homo.
go a find a 3.4L. I'm sure you could find everything needed and a low mile engine for around 1000
Quick Reply: Head Gasket
