wolfrunners sas and chev spring swap
#62
cause my angle off the t case is like 38 degrees at ride height and if i go too fast ill toast the u joints or rip[ it apart. if i had a hi pinion diff i would knock 10-12 degrees off, ps i dont run a cv even a 85 clearanced one would bund a little im single joint on both ends, 2nd gen runners have a little bit longer finger on the yoke that hold the u joint and can run at an extreme angle without binding compared to first gens which had shorter fingers on the yoke
#63
80 series land cruisers i think, trail gear sells the hi pinion housing and you can swap over a carrier and im not sure about the gears but you would probably want to get new ones with a hypoid cut instead of standard, i could be wrong someone will correct me im sure
#67
plus i have been trying to figure out why my runner leans to the right by about 3".
Flying91
45
04-11-2024 04:39 PM
Backcountry411
07-24-2015 08:06 AM
