General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
The really small light bulb inside the hazard or rear window defroster switch
Old 01-24-2006, 11:08 AM
runethechamp's Avatar
Does anyone have any idea where to get this one? I got my hands on a used OEM foglight switch from Japan for my 94 4runner, but when I was trying to figure out how to hook it up something was not right. Turns out there is a small lightbulb inside this switch (I assume it is the same setup for the Hazard and Rear heater switches since they have a constant backlight when your headlights are on), and this small lightbulb is not working. It' seated in a small white plastic socket, and it seems like it's stuck in there.
Old 01-24-2006, 11:40 AM
UKMyers's Avatar
The bulbs in those switches and the sockets are all one piece. The socket has a phillips style head on the back of it and you rotate it a quarter turn to get it out of the switch itself. I went through this when I made all my backlighting blue. I broke a bulb off trying to get it out of the socket and then I realized it's all one piece. Toyota carries them. I went to a junkyard and swiped a couple. They are all the same for the AC, Hazard, Rear window, Rear defroster, ect.
Old 01-24-2006, 11:53 AM
Cool, thanks! I see you live not too far away from me... What junkyards do you go to in the area?
Old 06-10-2007, 02:23 PM
DrAnonymous's Avatar
I've been trying to track down the actual stock bulb that goes into those sockets. I called the dealer and the bulb with socket is $9.00, which is crazy. I need 3 right now and I'm not paying $30 for those teeny things.
After poking around and using a set of calipers, it looks like this might be an 8640 bulb. You can see one here -
http://bulbster.com/lightbulbs/8640-p-2475.html
The only thing is the wattage seems a tad low.
I'll post once I've ordered some.
Cheers,
DrA>
gillesdetrail
11-19-2019 12:56 PM
warrenjcarlson
07-22-2016 11:47 AM
voiddweller
19
05-02-2016 09:10 PM
Corey
06-19-2002 11:06 AM
Quick Reply: The really small light bulb inside the hazard or rear window defroster switch
