85 4Runner A/C Question
The A/C on my 85 4Runner only works every now and then. Sometimes I get in and it will blow cold air and other times nothing. Sometimes it will stop working if I hit a hard bump.
Is there some sort of impact sensor that would shut it off or do I have a loose wire somewhere? I didn't see any switch on the wiring diagrams in the FSM but maybe it is built into another component. Any other ideas?
Thanks
Thanks
I would say you either have a loose conection some were or a bad relay. the relay for the a/c (if i remember right) is under the dash behind the radio.
Thanks
Thanks
TURBOrunnerNM
07-22-2015 11:01 AM
