toyota lying?
my truck smokes too in the mornings. try running some seafoam in it. see if that works.
but if it doesnt sound weird, i think your okay.
with the non starting... i have no idea. toyota should have found out something with that. hmmm.
if it smokes a bit in the mornings, thats normal! thats the truck warmin up, burnin off the MOISTURE in the muffler and everything. now if youre losing fluid, constantly have a THICK white cloud, then yeah its HG time.
theres WAY more to a blown headgasket than just white smoke. When i had mine go, it never failed to start, but it ran like crap. It would overheat as quick as it could get to operating temperature. I had a valve go in my poser steering vacuum lines and that caused white smoke, too. Does your exhaust smell like coolant? Are you losing coolant quickly? Also, if they did 'tear the engine apart' wouldn't they have had the head off and then had to change the headgasket?
doing a headgasket job right now on a 22r and i gotta rebuild a 22r in our 87. Both had the gasket fail on cylinder 1.. weird.
Consistent white smoke = headgasket failure.... A real eassssy way to check is to take out the spark plugs (all 4), ground the ignition to the block (or leave it hanging away from anything so it wont arc..
turn the engine over about 4 times. When water comes spraying out you'll know the HG is toast =) ... btw this the same procedure to do a compression test.
#26
To test compression, you need a compression tester. They are a gauge that has a hose that threads into the plug hole. Pull all the plugs, ground the coil, then crank the engine over until the needle moves 4 times (you may need an assistant). Repeat this for all of the cylinders.
Low compression could mean a variety of things:
Here are a few:
Worn Rings (doubtful)
Worn Valve Seats (doubtful)
Head Gasket (Likely)
Valve Lash (My Problem)
You are likely to find you have lower compression on one or maybe two cylinders than the rest, if it is the headgasket.
Here are a few:
#29
easy way to tell if you got a dead cylinder(low or no compression) is unplug the coil from the distributor and crank the motor. If you hear the rpm raise and lower as you crank it then you got a dead cylinder(s)
#33
you can always call Toyota customer relations, they do seems to take complaints seriously. threatening a lawsuit always works, too. it's very legal pretending you know alot of legal stuff.
seriously, how long was it btween you drop off your truck and they told you they tore up motor? IIRC, it takes a good shop 2 days, a dealer 2 weeks to do that.
09-04-2015 09:27 AM
