Need help. Water temp sensor thread
Was screwing in my new temp sensor for the gauges on my truggy when this happened?
Anybody know the actual sensor thread that goes into the adapter? I'm guessing it's some kind of NPT.
If your trying to put that manual temperature probe into that adapter you broke most likely it is not going to work as you found out
It bottomed out before it tightened up
The best way is into the top radiator hose they make metal tubes with the correct size fitting welded in or you can make your own.
I make my own
I would have to double check the correct size of the threads in the manifold
I make my own
I make my own
I make my own
nuknuk
07-21-2016 07:04 AM
red247wings
05-13-2016 04:15 AM
sharrack
11
05-10-2016 07:09 AM
1994toyotatruck
05-09-2016 06:59 PM
Turtl3
05-09-2016 04:04 AM
