heater problems
Old 03-11-2009, 11:01 AM
Brutis1656's Avatar
heater problems
the heater use to not blow enough air so i tore it apart cleaned it it out and replaced the fan and it still would not blow hard enough.(when on high it felt like it was on low) now it wont blow at all and i went through the fuses.there is one labeled engine h that keeps blowing and i dont know where to go from here
Old 03-11-2009, 11:11 AM
Staff
DeathCougar's Avatar
Check your fan switch. Those like to melt and ground out, causing the exact problems you are describing.
Old 03-11-2009, 11:22 AM
Brutis1656's Avatar
so time to tear the dash apart
Old 03-11-2009, 01:05 PM
Adam F's Avatar
blower motor resistor searh 4crawlers page he has the fix
Old 03-11-2009, 08:21 PM
Brutis1656's Avatar
turned out that the fuse was god but not getting a good connection through boths ends on the fuse panel so i cleaned the terminals and the heater works again but still blows like its on low when i have it turned on high
Old 03-12-2009, 06:10 AM
Adam F's Avatar
clicky clicky
Old 03-12-2009, 07:09 AM
Brutis1656's Avatar
thanks man
the1998sr5
15
07-14-2020 08:35 PM
94 Newbie
08-06-2015 10:33 AM
Logz808
07-26-2015 07:09 AM
jjrbus
07-23-2015 05:05 PM
the1998sr5
07-16-2015 06:20 AM
Quick Reply: heater problems
