fuel filter replacement?
I am just curious why so many people in here are advocates for replacing fuel filters. If going by TOYOTA'S recommendations you should never need to replace your ff under normal conditions. We have a customer with over 600K on his 3.0(original block no rebuild) and have never replaced his filter. I'm not at all trying to bash anyone, just curious is all
Location: I live in Red Bluff ca. Right by the Sacramento river
600K from a 3.0? Wow I always hated those engines, not worth the metal they were made from in my opinion. I think I may have to declare bs. As far as the fuel filter goes, I dont think toyota was expecting us to put these trucks through what we do, at least not mine. You can run the same air filter forever also, it will run, but will it be at its top condition? Probably not. We just do it for peace of mind, and preventitive maintenance. Plus they cost like what? 5 bucks?
Thanks toytech76
Phil
I had my 884runner since 03 and changed my fuel filter once so far with one from k&n and havent had any problems but on average i would change it every couple of years it saves from surprises around the corner
under ideal conditions (fuel filtered from gas station, some are some are not) then i could see the fuel filter lasting a long time, but most gas stations don't filter their gas from the tanks or if they do its not much
I've seen the insides of too many old fuel filters to leave mine go.
Like I said...normal conditions. lol Im sure toyota doesn't consider drowning normal. lol Redbluff...honestly no BS! I agree the 3.0 is a pile of junk. They have sure made me alot of money tho. The guy had a couple valve jobs done which can be expected as they burn ex valves like nobodys business. Phil...as long as you maintain your truck regularly you can hit 600K. Change your oil every 3k. Adjust your valves every 60k. Plugs every 30k. Go by the factory service schedule. If your truck is used really hard maybe do your services early. We even have several customers who have over 300k on their 3.4's. Just a matter how you maintain them
600k miles??!! That's quite an accomplishment. Then you figure in the $ in gas. Giving it a GENEROUS 18MPG, average fuel price of $2/gallon. We're looking at ~$66,000!!!!!!!!!!!
TURBOrunnerNM
07-22-2015 11:01 AM
