Friend's oil drain plug stripped
hi yall im posting for my friend
he has a 1986 Corolla GTS (AE86).
he was trying to pull his drain plug from his oil pan to do an oil change. he stripped the heck out of it and pretty much the plug is round now. what can he do to get it out?
any suggestions?
thanks!
any suggestions?
thanks!
Just about the same thing that you'd do for any rounded bolt. The first thing that comes to mind, of course, is some good vice grips. Might help to spray it down with PB Blaster if possible - sounds like it's on there pretty good.
Search rounded bolt and I'm sure you'll find a whole long list of other ideas as well.
Grab a set of Bolt Out's. They work AMAZINGLY well! I Was hesitant at first, figuring they would probably just mangle the bolt, but I had a gift certificate so I got them. I have used them 8-9 times now on multiple different vehicles and I am in love. They are my new favorite tool!
First I would go to the store and get one of those universal drain plugs that look like drywall anchors with the wing on them. Like this....
http://cgi.ebay.com/ebaymotors/UNIVE...QQcmdZViewItem
Then try a vice grip to get it off.
Last ditch effort would be to take a cut off wheel and slot it, then use a large pry bar like a screw driver to get it off.
Or....abandon all hope of ever getting that plug removed. Several oil service companies (oil butler, here in town) will suck the oil out via your dip stick tube.
That wouldn't be my solution - but if you take your car to jiffy lube its really no big price difference.
Originally Posted by joshik
what if, instead of slotting it with a cutting wheel, grind the sides to make it a smaller plug, like 13mm or 12mm.
where would u get a set of these? i did a search on YT and dogpile. couldnt find much info on them.
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
Originally Posted by Ringmaster
Small pipe wrench.
The harder you pull the tighter the wrench gets, until it breaks of course.
06-01-2021 01:51 PM
