Cleaning out rear axle housing
Old 06-11-2008, 09:39 AM
904_runner's Avatar
Since my bearings were bad in my third and i took it to a shop to get it rebuilt and i am waiting for it back, i have been cleaning out the inside of the housing.
My question is, is there a secret to getting almost of the tiny metal particles out of there? I have used a whole roll of shop rags, two cans of brake cleaner, and a magnet. i think i got most of everything, but would it be okay to put everything back together and then change the diff fluid in a few 100 miles, and cleaning the drain plug magnet then?
Old 06-11-2008, 09:43 AM
dirtoyboy's Avatar
Yes, you did it right......I would just give it a shot of compressed air and then call it good.....the magnet on the drain plug should pick up any leftovers
Old 06-11-2008, 09:47 AM
904_runner's Avatar
Alright, i spent, what felt like a couple hours cleaning in there. Sometimes i can get a little more particles on the rags, and was just wondering if it sounded good enough.
I was told i could put another flat magnet in the housing and leave it there to collect more, would you guys recommend that? I think i won't even bother unless it is a trick of the trade i am not familiar with.
Old 06-11-2008, 09:55 AM
grovedogg's Avatar
i think you'd be good just changing the diff fluid after a couple hundred miles just to be safe... i don't think i'd be comfortable leaving something in the diff housing...
Old 06-11-2008, 10:17 AM
904_runner's Avatar
Thats what i was thinking, because my luck would be that ring gear would pick up that magnet and then, well you know...
Okay, when i put it back in i am just using a 80w90 valvoline synthetic blen, so when i reflush it should i use the same weight oil and the same stuff or should i try that redline shockproof? Now this will be with the stock gears but new bearings and a lockright. So in that case should i use a thicker oil? Basically what are your thoughts on the subject?
Old 06-11-2008, 10:21 AM
881stGenRunner's Avatar
i have a Detroit, 5.29s and cryo bearings from Zuk and i still use 80w90. Only thing i would reccomend is to use a full synthetic oil.
Im assuming you know how to properly break-in your new gears?
Old 06-11-2008, 10:22 AM
904_runner's Avatar
Im not getting new gears, just a rebuild of new bearings
Old 06-11-2008, 10:25 AM
dirtoyboy's Avatar
NO, hes talking about the magnet on the drain plug....
I have heard of people putting magnets in their diffs (drag racers and stuff do it) and them staying put.... but I sure as hell wouldnt try it...gears aint cheap by any means!
ok good. just make sure you use full syntec. Its better for the gears and keeping everything cool.
Old 06-11-2008, 10:27 AM
904_runner's Avatar
Is that shockproof stuff full synthetic? OR what would be best, mobil 1?
Regency
20
01-03-2020 07:43 PM
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
A2theK
07-12-2015 10:46 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Cleaning out rear axle housing
