4runner versus Jeep Wrangler?
Originally Posted by grimpy
Yeah... I have a 2.5" suspension lift and 2" bodylift and had to do pounding and trimming to fit my 33's without rubbing on turns... No idea where you got fitting 33's stock unless you mean some major fender mods....
As I stated above, it's all about preference. I'm not trying to say that a Rubicon is better than a 4Runner. As X-AWDriver said, with the Rubicon you get full factory warranty on all of the parts that you would normally get used to do a sas on a 4Runner. If I had the money, and I didn't want something that would last me forever, I would get a newer Rubicon as they are cheap to build and parts are cheaper for them than the 4Runner. That being said, I don't have money and I do want a reliable vehicle that I don't have to worry about so I'll stick with my 4Runner and build it to out wheel those dang Rubicons.
Originally Posted by tc
Read above - first and second gen can run 33x10.50 with no lift.
I was actually referring to this...
Originally Posted by 91 4Runner
Test 1995 Wrangler
Front Impact, Driver 2
Front Impact, Passenger 4
NHTSA Crash-Test Results
Test 1999 4Runner
Front Impact, Driver 4
Front Impact, Passenger 5
As far as personal preference on both...
Wrangler 4.0L and solid front and rear axles - pro
dana 35/30 front and rear axles - con
lack of cargo space and 1 seat - con
wheelbase - too shor and feels unstable at or about 40 to45 degrees incline
4Runner - no lift really required to use 33's - pro
IFS - con ((for offroading)cannot be beat on the road))
Cargo space -when you have 3 kids and 2 100lb dogs - space is a plus
Longer wheelbase is more stable at increased angles... 11.3" is better in my book...
Looks like he was comparing a 95 Wrangler against a 99 4Runner...
Originally Posted by ToyoRunner94
what about the I6? I6's may be reliable, but i was comparing it to the engines toyota uses. i was just saying the wrangler cant boast of a V8 like the 4runner, the best it has is just recently getting the V6.
my folks have had XJs and ZJs in the last decade, and they've been pretty reliable. as somebody above said, the biggest problem is with the transmissions(made by aisin, i'm not kidding), and the exhaust manifolds cracking.
#25
#26
I guess I should have put that on my Runner I can run 33's no lift... As far as the comparasin goes it was actually a 95/2000 Wrangler and a 96/99 Runner....But the the comparasins were really for wheelbase/cargo area/impact strength - For what consumers really want...
#27
Originally Posted by paddlenbike
The Aisin trannys are not troublesome, it's the trannys made by Peugot that didn't hold up. The AX15 5-speed in the Cherokee is the same as the R150s used in V6 Toyotas and very similar to the R154 in my Supra Turbo. (The gear ratios are different though.) BTW, I'm making 425 hp and 485 ft lbs of torque and I am no where near the limits of the R-series Aisin tranny.
#29
I have a 93 4runner and a 93 YJ and i'd take the runner any day. biggest prob with the YJ is space. I'm about 6' tall and the driver's seat in the YJ is way too close to the dash for me, at least 6-8". rediculously uncomfortable as a daily driver, at least in my opinion. It also seems to have alot less ground clearance than my 4runner (i've never measured it but i definately can't just roll under my YJ like i do my runner!). Can't really say much about reliability, for the above reasons it doesn't really see the miles that the runner does. Pro's on the YJ are the convertible top, you can basically hose out the interior, and mine has a big-a$$ winch on it (it needs it more than my yota)!
#30
You've mentioned ground clearance. I'm not sure about 2nd Gen. and YJ, but I can tell you facts comparing 4th Gen. with TJ. This October I took my new 4Runner to the trails first time in his life. 4Runner handle easy trails pretty well, I didn't stuck. But I can't tell the same to my skid plate. At that time my 4Runner was 100% stock. My skid plate was looking like I slide on it whole trail from the beginning to the end, it was all scratched and had ~10 deep dents. At the same time TJ, which was in front of me didn't hit his skid plate or any other underbody parts not even ones. I was hitting every rock, every stone on the trail by my skid plate and exhaust. This shows up that stock 4th Gen. 4Runner has less clearance then stock TJ.
I completely agree that with a lift and good tires I'd be at least not worse then TJ, probably better. We had slightly modified 3rd Gen. on that run and I remember he gone all the way on medium level without any problems.
#31
A big difference is the wheelbase and how they ride. Jeep=short wheelbase, two solid axles... bumpy see-saw ride....
As far as reliability go... Maybe in the past the jeeps where truely heeps... but give them a few years with Daimler running stuff and I bet they're as reliable or more reliable than a toyota...
That's the future men and women... If toyota doesn't start coming out with a solid axle front to compete with an ultra reliable Mercedes Jeep Rubicon with Mercedes Diesel option... I'll see you boys at the Jeep dealership.
And now the Jeep has an extended wheelbase model so nevermind about the wheelbase argument... Pretty soon Toyota 4x4s will be classed with others like the Isuzu 4x4, and Honda CR-V. It's true and everyone here knows it. Toyota is WEAK by not offering a SA front. And they'll see a sales hit when Daimler has their way with the Jeep. A Jeep with a Mercedes Diesel and SA f/r. A Jeep more in tune with a Mercedes G-Wagon than a soft riding, leather pampered, traction controled weak little toyota 4Runner that soccer moms buy.
Does the truth hurt... somebody better email Toyota then
If you want a true off-road vehicle, get a wrangler. If you want a livable DD and capable 4x4, toyotas are pretty good. If you want to see a major difference in the two... Roll a wrangler then roll a 4Runner and see what happens to the two and which is easier to fix.
#32
Has anyone looked at Jeep's concepts? Toyota better step up or stand down.
They've already dropped the 2.8L Diesel in the Wrangler (from the factory) LINK
LINK
Gladiator is powered by the modern and efficient 2.8-liter, 4-cylinder common-rail turbo diesel engine that provides 295 lb-ft of torque and 163 hp. It delivers ample power to all four wheels through a 6-speed manual transmission and a traditional part-time transfer case.
Worldwide Availability
Sold in key international markets throughout the world, the all-new 2007 Jeep Wrangler is available with a Diesel engine, as well as left- and right-hand-drive models. Built at Chrysler Group's Stickney Avenue Toledo Assembly Plant in Toledo, Ohio, the 2007 Jeep Wrangler will arrive in Jeep dealerships in the fall of 2006.
#33
Ultra-capable off road vehicles is a very small niche market more than amply covered by the Jeep Rubicon. It would be impossible to make a business argument for Toyota to start importing a vehicle like that.
So, unless we get everyone with a TRD Taco and 4Runner out on the trail realizing what an asset a locking diff is and "create" the market for super articulation to go with it, no businessman in their right mind is going to sell a vehicle like that.
#35
LoL, Not a traitor, just pissed that we can't get the good toyotas here in America. I would love to have one of the basic, no-frills, solid axle, diesel yotas...
I think we need to contact J.W. Bush and have him call Toyota about this terrorist act against America... or, maybe have a trade embargo that toyota must only sell solid axles to help GM out....
I'm sorry to say it but my next truck purchase will more than likely be a Jeep with the Mercedes diesel... I just don't like IFS. I don't like the way they go over speed bumps at an angle or anything... I don't like cushy shocks, I like a truck to drive like a truck.
#36
Easy as that... just like they already do in most of the world...
#38
Originally Posted by drguitarum2005
Don't get me wrong by the title, I'm 4runner all the way. My friend asked me the other day why I didn't get a wrangler if I wanted to do wheeling (innocent question, he knows nothing about wheelin) and I couldn't give too many matter-of-fact reasons, so thats what im here asking about. Are there are mechanical/structural differences between the two that makes a runner that much better than a wrangler when it comes to wheelin? Thanks guys
#40
no leg room - ZERO for all occupants.
uncomfortable seats.
crappy dash instrumentation and interior ergonomics
zipper rear window with no alarm = easy target
oh, and that zipper was seized on our top - and it only had 7k miles on it in ARIZONA.
i hated it. so much so that there's NO WAY i'd want a newer wrangler -even a Rubicon or Rubi-Unlimited. i'd do a 70's CJ WAY before i dropped that much money on something so craptacular.
06-01-2021 01:51 PM
djpg2000
11-11-2020 04:56 AM
jasonty
41
12-23-2018 01:00 PM
