350 swap Questions
350 swap Questions
Im thinking about buying a 91 toyota pickup with a SBC 350 swap with a np205 transfer case and th350 trans. it also has a SAS swap in it. it has 39.5" tires on it now but later on down the road after i fix the little stuff thats wrong with it i want to go bigger. This truck wouldn't be a daily driver but wouldn't be just for wheeling either. but I have a set of 5.29s with a locker in my ifs truck now. if i got the truck with the 350 should i swap my 5.29 gears to that truck??? if not what is the best gears to run with a 350 swap??? thanks for any info.
im running a 82 toy with a 350 motor turbo 400 trans and 205 t case i had the old 529's in it after dropping in the chevy drive line and the diffs hated it WAY too much torque for the 529's im running stock 4.10's with a locker and they hold up well as 4.10's have the most tooth mesh with the pinion, enjoy
09-04-2015 09:27 AM
