Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
Side Marker Blinker
Old 01-19-2018, 08:11 AM
stovetop36's Avatar
Side Marker Blinker
If you have lost your blinkers because you got a new bumper or like me just think having your blinker down low, only on the front of the vehicle is stupid than this video is for you. I had researched turning my side marker lights into blinkers for a while but, there wasn't a method that didn't look overly complicated or a bit messy. I know Jimmy isn't the one to come up with this method but, his video is the first I have seen that explained it well enough I knew I could tackle it. Really it is super simple.
Check out Snail Trail 4x4's video here :
A note, my 4runner is an 86 and the flasher is actually located behind the kick panel on the drivers side just below the fuses on the fuse block. The EL 12 flasher Jimmy uses doesn't fit in the space on the fuse block so I used some jumper leads. I will post some pictures when I get a chance. Also hoping some LED's 194's I have around will work with this. I will update if they do.
stovetop36 is offline
Old 01-20-2018, 05:00 PM
stovetop36's Avatar
Works
Got the side markers working right. I used the EL12 Jimmy uses in the video. But, in an 86 4runner the flasher is located on the fuse block, behind the driver side kick panel. It won't just plug in so had to run some jumpers. Bonus the EL12 works with LED 194 bulbs without a separate resistor. I also removed the blinkers from the bumper. Found some LED floods that should fit right in there. I'll share when I get them installed.
Old 01-22-2018, 09:02 PM
Kolton5543's Avatar
Make sure the led bulbs you buy support reverse polarity. Some do some don't. If you get one that doesn't you will get markers but no blinkers. Or if you flip the bulb you'll get blinkers but no markers.
Kolton5543 is offline
Old 01-22-2018, 09:05 PM
stovetop36's Avatar
I musta
I​​​​​​ must have got lucky because the ones I already owned worked perfect. They can def be tricky though. Especially with cheap over seas stuff.
Old 02-19-2018, 01:12 PM
Indetrucks's Avatar
This is a very handy bit of information, thank you for sharing. I will be looking to do this in the future for sure!
Indetrucks is offline
Old 02-19-2018, 03:38 PM
YOUNGIAM's Avatar
Subscribed .
YOUNGIAM is offline
PmB
06-27-2013 04:57 PM
hurley842002
02-03-2009 01:20 PM
KU_MechE
09-24-2006 08:45 AM
apc
7
09-03-2002 05:30 AM
Quick Reply: Side Marker Blinker
