will a 1992 toyota axle shaft fit into an 84?
my question is exactly what the title says, will a 92 toyota pickup axle shaft fit into a 84 pickup?
Yours is a solid axle front. As was stated, 79-85 solid axle parts work for you. In 86 they went to IFS front (in the States) so to match the necessary width of the new IFS fronts, they went 3" wider for the rear diff. It's a common upgrade for us early solid axle guys. IFS rear diff assembly offers more stability and bigger drum brakes. In my case, everything bolted into my 84. Just get the IFS leaf spring U-bolts if you get one from a yard. The diff tubes are a bit larger in diameter.
6th Gear
19
12-10-2019 07:31 AM
RaginAsian91
07-27-2015 07:11 PM
