Truck does wierd stuff on startup
Old 07-12-2012, 09:10 PM
solidaxle85's Avatar
Talking Truck does wierd stuff on startup
Hey new at mechanics here..just learning i was wondering if someone could help me out
My truck when i try and start it up in the morning most of the time it sputters at like 900 rpms and keeps sputtering and sometimes it sputters till it stalls other times it sputters till it starts. I put some seafoam in the gas tank to see if i could clean the injectors out a bit without having to take them out, and it was going good for a bit then decided to do it again. Would anyone know what this could be?
Old 07-12-2012, 09:11 PM
Also its an 86 22re
Old 07-12-2012, 11:11 PM
wyoming9's Avatar
a little more history might help
When was the last time it had a major tune up??
Air filter, wires, cap, rotor and sparky plugs
Has the fuel filter been changed lately??
Toyota said these were life time filters but that statement was made before the great addition of ethanol to the fuel system .
Have a habit of driving around with a below quarter gas tank??:jessica::jessica:
Most of these engines start with the turn of a key although if people had there hands in the emissions systems it can cause interesting problems
Old 07-13-2012, 06:34 AM
Cleaned the air filter, changed the plugs and wires haven't dont rotor and cap and the fuel filter has not been changed lately, and i drive under quater when im out of money usually its above half
Old 07-13-2012, 07:48 AM
SPARKS89's Avatar
It sounds like you might have a problem with your cold-start injector. Another thing you can do just for good measure is SeaFoam the motor itself. Pull the vacuum line off the brake booster and plug it with your thumb. Have a buddy keep the rpm's up and move your thumb out of the way just enough for the vacuum to suck SeaFoam past your thumb. DON'T LET THE ENGINE DIE WHILE YOU'RE DOING THIS. Get about half the can in there and shut the engine off. Let it sit for about 15-20 minutes then start it up again and get ready for smoke. After about 30 minutes of idling you should have successfully killed every mosquito for 3 counties...and cleaned out your engine too.
Does it run ok after it's warmed up?
Old 07-13-2012, 08:44 AM
4Crawler's Avatar
Might try the fuel pump test jumper and see if that makes any difference:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
If so, it could be the fuel pump is cutting in and out for a while right after starting.
Old 07-13-2012, 04:52 PM
It runs not terrible when warm. I just bought a fuel filter rotor, and cap at work, will change those. After if it still is acting up ill do the seafoam, then test the fuel pump
Thanks for the replies
- on a different note i also got my cata taken out now it sounds pretty badass!
Old 07-13-2012, 05:05 PM
TylerH's Avatar
Mine is the same way. Dont feel alone!
Old 07-13-2012, 05:44 PM
TylerH loving the sig im the same way..LOL
Also Changed the rotor and cap, no time to do the filter. So ill see if that works!
Old 07-13-2012, 06:07 PM
fork's Avatar
aux air valve?
Old 07-13-2012, 08:20 PM
ksti's Avatar
Have you checked for any vacuum leaks?
Old 07-13-2012, 10:02 PM
TylerH's Avatar
Thanks. Changing the fuel filter is a little frustrating. Maybe grab a few more crush washers if you plan on doing it soon.
Old 07-15-2012, 09:22 AM
SO yeah it's not my rotor and cap time for fuel filter.
Then the fuel pump
Old 07-23-2012, 02:09 PM
Cadin's Avatar
Status?
Old 08-18-2012, 07:51 PM
Ahh sorry for the wait guys...its my timing chain. i have drained the oil and antifreeze removed my rad and fan. while im waiting for my haynes manual i may aswell have a beer!
lledwod
09-06-2016 07:33 AM
bigblue82
10
07-06-2015 08:27 AM
shadowbirdie
06-24-2015 03:54 PM
dirtrider0129
10
06-24-2015 12:24 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Truck does wierd stuff on startup
