questions about a sas??? please help!
im looking at a 5" HD sas kit. but im thinking of doing a 5.0 v8 swap if i did the sas would the toyota axel be able to hold up good or would i have to buy a ford axle? and if i did buy the ford axle would the sas kit work with a ford straight axle or is there another kit for that? i have also thought about the 30 spline longfields but would they fit in a 85 straight axle or would i have to get the dana 60? would the sas kit work for the dana 60 or would i have to peice it together?
someone please help im confused. im new to toyotas and dont know much about them.
No, SAS kit for a Toyota axle won't work with a Ford axle or the D60. There are kits for 1 ton swaps.
You need to do some searching and a WHOLE lot of reading.
the ford 302/5.0 is just what i have in my garage and i love those engines.
will the 30 spline longfields work in the toyota straight axle? because i hear that will hold up just fine?
i have searched a little but couldnt find anything is there any where you can dirct me to?
I have seen a 5.0 in a SASd Toyota 4Runner that was well built and all the 5.0 did was blow stuff up...from R&Ps, to axle shafts and a tcase output or two. 5.0 is too much HP for Toyota running gear.
If you want to run a V8, get 1 tons.
thats what i started thinking about doing the v8 swap and putting dana 60 in the front and rear.
i just need to find the kit or something to put in the dana 60's. i want to start looking for a ball park price that everything is going to cost me.
thanks for the post and help by the way
Flying91
45
04-11-2024 04:39 PM
Shagool22
08-14-2015 12:24 AM
TJWilly
07-31-2015 02:05 PM
