Peeling stickers of truck
Any ideas or proven methods to peeling the decals of the sides of a 4Runner ? The truck I recently bought (in my avitar) has the side decals half peeled off and I want to remove the rest.
Derek
Derek
I've only done this once before, and that was when I removed TOYOTA from the tailgate on my '90 pk. I used a hair dryer and small plastic putty knife and took my time. There are some other posts on here dealing with this topic. Try searching around.
Here's a few more answers I found online...Good Luck, and welcome to YotaTech!
http://answers.yahoo.com/question/in...=1006021310585
I dont know how well this would work for a side graphic but they work wonders on pin striping and vinyl decals. Its basically a rubber eraser that you put in your drill. A link to and example... http://www.tcpglobal.com/autobodydepot/adhremove.aspx check those out. If you have a automotive paint store around they would most likely have them. Hope it helps...
goo-gone works really good with a little heat and a plastic putty knife as stated above.
and wd-40 works really well and no it will not hurt your paint/ clear coat
take your time and if you turn a 5 gallon bucket upside done to sit on it is almost the perfect hight for that kind of work
Thanks for the input, I'll be starting to remove them on monday. The truck was originally from Florida so the decal are quite dry (sun baked) and don't peel to easy. I've tried picking up an edge and peeling with out heat and I get very tiny little pieces. So I'll be trying the blow dryer and various chemicals.
Derek
Derek
anyone experiencing "fresh paint" stripes after removing the decals? Mine have been on for 13 years and my runner is black. although the paint is in great shape...this california sun has baked those decals on....will there be stripes from where the decals have been? I like the look of no decals and was thinking about taking them off...but DO NOT want there to be evidence of them once being there./
any advice of own experiences?
thanks guys
thanks guys
as usual, 4crawler's website has an answer http://www.4crawler.com/4x4/CheapTricks/Stripes.shtml
Do not use goo gone or the power washer.At the body shop we use a rubber buffer wheel on a die grinder.Its a soft rubber wheel,and takes decals right off.Then we buff the side of the vehicle. I just did my 93 4runner and did all the body work in fiberglass.No glue marks at all.goo off can damage the paint,and the power washer also.
the rubber easer works awesome. in the drill and go. I used mise for the sunset stripes around the whole truck, took 20 mins and the paint isn't damaged at all.
Your paint, like the decals, has been sun faded over time.
The paint underneath the decal will be completely unfaded and unscratched.
That will make it very easy to see where the decal once was.
Nothing a thorough session with the wool pad won't take care of
