Need Steering Wheel Gudiance..
I have a gt grant steering wheel currently on my 87 toyota pickup and i wanted to get an original toyota steering wheel like this its from an sr5 and do not know if it would fit? could someone enlighten me on what would have to be done.
pull the grant wheel off the 5 pointed spacer that it bolts to, remove the center nut from off of the column, remove the three bolts at the back of the steering wheel spacer that hold it to the aluminum adapter piece. once you've pulled off all the stuff for the grant wheel you will see the exposed horn contact sticking, etc. Now simply put the toyota wheel on and bolt it down. It helps to start with the steering centered and locked.
Thanks a lot for the quick replies... very helpful
sorry to reject your offers im getting one just like the picture for $15
terminator
07-27-2015 07:13 PM
