manual to auto
Problems i'd look for. Linkage for gear selector, tranny cooler lines to radiator, and Speedo cable. That's all i can think of. Make sure the transmissions are the same length or you will have drive shaft issues. And dont mix 4x4 and 2wd trannys
its gonna be an involved project. i recently finished my 3.4 swap going from a 22re 5spd to a 3.4 auto. from what i understand you will have to change wiring harness, ecu,trans,radiator, shifter console,etc. it probably would be cheaper, and a lot easier to trade cars.
TransAmBandit
07-28-2015 11:30 PM
