Long Travel kit for IFS a good idea???
I was wondering if instead of doing a sas (Because of the cost) If the long travel kit for the Ifs would give more flex and even be worth it?? What do you think, I have not really looked into it or heard much about it
thanks for your help
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
So? Money's a problem? No kidding... Why does that seem the case with 99% of the trucks out there?
The best thing to do with IFS is leave it alone.
The 2nd best thing to do is NOT leave it alone...
And the 3rd best, is the convert it to SA...
If I had to build an IFS truck on a budget, you better believe the FIRST thing I'd do is a body lift.
Without a doubt, the strongest IFS is what the truck came with stock. If you BL it, then you can go to BudBuilt and 4Crawler and get the drivetrain raised up.
This makes nothing hang below the frame, and lets you get a bigger tire on the stock IFS suspension.
Then, you can decide if BJ spacers and FJ80 coils, or lockers are the next best step.
B/c make no mistake traction (diffs) beats the wee out of flex any day of the week.
Woah! First off, what kind of driving do you do? Desert Baja? Like to go fast on mild dirt roads? Baha is the bees Knees for Long Travel. Rock Crawling? Not so much. Where do you live? A little more info would help in pointing you in the right direction....
Also you get what you Pay for. A good long Travel kit can cost as much as a SA conversion.... Just sayin!
I live in paradise,ca its an hour and a half north of sacramento, its mainly rock crawling and dirt roads. everyone up there runs a sas it seems. So if they are even close to being the same price I will solid axle it no questions asked
Well then you need to convert to SA...
B/c no matter what you buy, what kit or how it works, you still end up with a 7.5" stub axle with 2 CV joints per side before power can even get to your tires...
And save us the cost and finding someone to fab it up speech. It's a fact of life we all already know...
Yes, we all know it's too bad Toyota didn't offer the 4Runner with a solid front axle.
Budget, lol...
If it's an old used axle it will have Birfild soup.
If you don't do this you'll go through all the trouble of converting it and more than likely blow the axle joints within the first couple trips off road.
http://www.marlincrawler.com/axle/fr...uckle-seal-kit
And if you continue to break joints, you'll get to know his guy.
http://www.longfieldsuperaxles.com/p...FJ%252d60.html
TheManOutside
06-18-2015 03:32 PM
XtremeOff-Road
16
06-27-2002 07:32 PM
