Key won't turn, steering wheel stuck - help!
i was leaving work today and i had a little bit of trouble starting my 94 toyota pickup because the key did want to turn. i got home and was going to go to the store and it didnt want to start again. then i turned the wheel so now the steering wheel is stuck also. someone please help i need my truck for work tmrw.
sounds like the steering wheel or ignition is in a bind try pulling the steering wheel hard toward the drivers door while trying to turn the key. The key in my 87 does the same thing from time to time this usually works though I have yet to find the true problem.
The key part of the ignition switch can wear out after years of use, try spraying a little PB Blaster or WD40 into the key hole and see if that helps, if not then you might need to have the key cylinder replaced.
Try jiggling the key in the ignition while gently jiggling the steering wheel back and forth.
I usually just the jiggle the crap out of both of them until the key turns - sounds like you need a new key or your ignition cylinder is worn down or both.
Also, next time, a thread with an ambiguous title like this is just going to get deleted.
You have to put more in it than just help so people can find it later when searching.
Good luck,
Fink
Good luck,
Fink
i bet you juse have to wiggle the wheel harder sometimes on a old yota id have to almost put my foot into it lol. go back and forth with key while going left and right on wheel with otehr hand
Try putting some graphite in there. It works wonders shoot a bunch in there and coat the key with it. Then slide the key in and out a few times and coat it and shoot more in, then try turning it. Almost every car I've ever had this problem with it fixes it. Graphite pwns 95% of stuck locks I've came across the other 5% we just had to cut or replace.
graphite isnt really a temp fix, its more of a should be done thing. You are susposed to lube(which graphite does) locks, hinges and greese certs often which most people never do. Call around to locksmiths and ask them about graphite..
jon.r
07-11-2015 03:34 PM
