got mud /water in my engine wat do i do ????
When muddin with some buddys bout 2 weeks had no problems with it then i went thrugh a deep hole and i burned my cluth out got pulled out then went home next mornini pulled out the dipstick and its covered with mud truck wont start or nothing wat should i do to get the mud/water outa my engine?
It was runnin befor but my clutch went out while it was in the middle my truck was runnin but i wouldnt spin tires that wen water started coming into the cab so i know i gotta replace the clutch , but can the 22re still run with some mud in it ?
It prolly could run with mud in it... but why would you ever want to do that?
Just drain it, flush, then flush again, then fill, idle for 10 min or so, drain oil, replace with fresh oil and filter....drive
Its got the 3vze, not the 22re.....but it worked for me.
djpg2000
11-11-2020 04:56 AM
09-04-2015 09:27 AM
