fuel injector difference????
i need to buy injectors for my 86 Toyota 22returbo i found some $32 a piece on amazon. The details doesn't say if its for a 22re or 22ret all it says "86-87 toyota pickup with 2.4l engine." Is their a difference, should i get remanufactured, or aftermarket injectors. What do you think?
I am guessing here, since I don't have an 22ret.
Get the p/n from the dealer using the title or check the boards that deal exclusively with that engine. Or call LC engineering or Putney's they would know much more than I.
Mine are all '88 so that is a different non-standard part.
Both the 22re and the 22ret are the same part numbers.
23209‑35020 (08/1985 - 07/1988) 4 $303.41
But just in case, check with the seller on amazon and see what it is for. If they say 22ret, call up a dealer and do some homework.
pyramid
07-30-2015 10:05 AM
HookahRoo
07-20-2015 07:06 PM
22re, 22ret, 86, difference, differences, fuel, injector, injectors, pickup, reman, replacement, toyota, yotatech
