Cold Water Driping on my feet???
This just started yesterday... it is hot as all get out here so I have been running the ac... well now when I take a right hand turn cold water drips on my feet! any help would be great thanks in advance
mikeh
mikeh
Your a/c evaperator drain tube is plugged. You will find it on the engine side of the firewall on the passenger side or towards the middle. A shot of compressed air from a blow gun will clear it out.
Edit: Also check to make sure the drain tube is still connected to the evap. case
thanks 94 that was exactly the problem, there was a lil mud clogging it up, I should have said pouring not dripping, b/c that is what it was doing, but all is well now thank you
the1998sr5
27
11-17-2015 09:30 AM
defrag4
07-31-2015 10:50 AM
HookahRoo
07-20-2015 07:06 PM
