cargo cover question
I just recieved a cargo cover from a 01 4runner. this should fit in a 96 w/out problems right? or some reason, it seems a little too wide and only 1 slot will slide in. Also I was told that it was "oak" but it is more of like a "tan" and doesnt match my "oak" rear panels. Did they come in tan? or both tan and oak?
Thanks for the help
Patrick.
Thanks for the help
Patrick.
Patrick,
The 01 was a tan they changed it with the body changes it is lighter. It should fit though. You may have to get the 01 mounting brackets but it should work I thought.
Thanks for the help
Patrick.
Thanks for the help
Patrick.
Lifted,
If you need the brackets I could get them for you at a local junkyard for cheap. See if you need them, I would call the dealer. Let me know and I will get them for you.
thanks for the help. I'm not sure if I want to spend money on the brackets if the brackets are going to be different then my panels. its going to look wierd
the1998sr5
15
07-14-2020 08:35 PM
cgilley
07-25-2015 10:55 PM
icentropy
07-09-2015 02:12 PM
