'99 4Runner LTD 4x4--upgrade options on a budget
Old 06-24-2010, 04:29 PM
crimson717's Avatar
I am currently new to the whole decking out my rig. I would like to know where I should start. Need new shocks and struts and eventually would like to add a suspension lift around 2''. Not sure what brands to be looking at and where. If anyone has any advice, I am open to any suggestions.
Ultimate goal is to add lift, new tires, bumper, winch, etc. Primarily looking for something on a college budget but will get the job done.
Old 06-25-2010, 04:02 PM
ivbeenrokd's Avatar
Bilstein front lift struts are pretty economical and it rides so much better than before. Here's mine:https://www.yotatech.com/forums/f200...-build-213936/
I think it's perfect!
Old 06-28-2010, 01:19 PM
brian2sun's Avatar
Do your lift when you do the shocks. It'll save you time and money and since the fronts are a pain to assemble, you're not going to want to do it all over again. Plus, you'll need to get it aligned twice if you do it in pieces. The Billies are very nice shocks, but if your stock coils are saggy and shot then they should to be replaced. You can save $$ by not buying adjustable Billies and just buying lift coils and non-adjustable, extended shocks. Check out Toyteclifts.com and search - this is the most covered question there is on here.
Old 06-28-2010, 06:03 PM
crimson717's Avatar
Thanks to the both of you. I'm beginning to look at shocks and bilstein are top on my list. I'll keep in mind the advice when lifting as well. I hope to keep it the cheapest I can.
icentropy
09-16-2020 02:47 PM
Colington
03-08-2020 09:51 AM
msane99
07-17-2015 10:13 AM
toyoda8488
07-05-2015 10:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: '99 4Runner LTD 4x4--upgrade options on a budget
