92 4runner running rough
I have a 92 4runner 3.0 I.ll be driving down the road and all of the sudden it will start to run rough if i give it more throttle it falls flat on its face. when i pull over to try to clear it i'll hold the throttle at one position the rpms will vari from 3000 to 4500 rpm i let off the throttle and it will not idle after a while it will clear it's self by reving the engine
Have you checked for Codes? Tune up done? TP sensor tested? MAS tested? There are 100 things it could be. You will need to do some testing and use results to narrow it down. There is no quick fix for this. Use link in my signature to open the FSM, and run diagnostics.
Follow the diagnostic testing on page 6 and page 8 of the FSM here and report your findings:
http://www.ncttora.com/FSM/1990-1995...e/troubles.pdf
Peteyg39@hotmail.com
06-26-2015 08:15 AM
