91 toyota 4 runner stuck in park pleas help
Old 09-06-2011, 07:13 PM
trout's Avatar
i parked my 4 runner and now it is stuck in park i did some reading and it sounds like it is a fuse that blew i had a trailer hook up to it i was wiring the truck and trailer... but i cant find where the fuse is... pleas help
Old 09-06-2011, 07:40 PM
87 Deathtrap's Avatar
My '95 4runner used to do this alot, however, it wasn't a fuse, it was the shift lock override. I'm not saying it isn't a fuse, but give this a shot if you can't find a blown one. Near your shifter there should be a small plug that you can pry off with a key. With the truck started, insert a spare key into the hole under the plug as you press the shifter button and pull back on the shifter. I hope this fixes your problem.
Old 09-07-2011, 04:49 AM
waskillywabbit's Avatar
Inside fuse block driver side kick panel.
Fuse for brake lights.
See the above post too.
:wabbit2:
gillesdetrail
11-19-2019 12:56 PM
MudnBullets
10-28-2018 07:00 PM
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
AustinTaco
06-21-2015 09:54 AM
NerfHerder-97SR5-
06-17-2002 05:31 PM
Quick Reply: 91 toyota 4 runner stuck in park pleas help
