22r engine install
22r engine install
Hello my name is Travis and I recently picked up a rolling chassis of a 1982 Toyota Pickup and a 22r engine/tranny/t-case. I was wondering if anyone in here could give me some tips since what I am working on I have never done before.
What I have completed is dropping this engine into the truck and waiting on the transmission since I don't know what bolt size to buy to mount the crossmember to the frame and tranny.
My question is if anyone has a guide for installing an engine into a truck that looks like it was a donor truck. I will include a list of what I have
Have:
Radiator
Alternator
Engine
Ignition coil
Transmission
Transfer case
Front & rear drive line
Power steering pump
I will attach pictures of what it looks like, most of the parts listed aren't installed in the truck yet because I don't know the bolt sizes for them either and I don't have spare bolts. Any suggestions other than going to a mechanic since I am trying to learn are much appreciated.
I should also note that the engine is from a 1986 pickup.
Have:
Radiator
Alternator
Engine
Ignition coil
Transmission
Transfer case
Power steering pump
Here are the images of what it looks like at the moment.
http://img813.imageshack.us/gal.php?g=img1598i.jpg
Ok I am starting to bolt in parts and I have a question about if all three of these connectors are for grounding. The connectors come off of the wiring harness just behind the ignition coil. Pics link below.
http://img72.imageshack.us/gal.php?g=img1601di.jpg
steve miller
10-10-2015 01:40 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
22r, 82, bolt, dimensions, distributor, engine, install, installation, motor, motors, pickup, size, tips, toyota, tranny, transmission, wire, yakimawa
