22r to 22re engine swap fuel help
swapping and planning on putting in the e2000 pump. question is the tank on my carbed 84 toyota pickup standard cab short bed has smaller fuel tank lines "the ones that are a part of the tank" are alot smaller then the ones on the donor 4x4 trucks tank which i cannot use because the tank is huge compared to mine. will this be an issue with not enough fuel flow for this swap? or would i possibly beable to find a tank off a 22re 2wd that would just bolt up to my 84 are the tanks interchangable/the same sizes based off standard/extended cab short/long bed 4x4/2x4 etc. thanks
taloolarunner
07-20-2002 05:51 PM
