1991 Toyota Pickup
1991 Toyota Pickup
My truck was running and it started to take longer to start and longer and harder to start as in turning over. Now all it does is turn over and wont even try to start. Any ideas on what is causing this. No Fuel, no fire or what? This is my first Toyota so I'm blind to them. Thanks in advance. Junior
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Is your truck bigger than a bread box?
Srsly... If it's EFI, you can jump the B+ to Fp, or reach in the AFM box and move the flapper. You'll have to have the key on to do this. And cracking the cold start injector is how you make sure the (fuel) system's primed...
So make sure if you crack the cold start, you are where you can disable the method you used to test it, fast.
Then fire... Go to harbor freight or Sears, get a spark plug tester. When you see it, it's directions on use should be self explanatory...
Air: Make sure it can breath...
Search "Toyota" "FSM" or "factory service manual" and find one on-line, download it, and PLEASE read the thing like a Stephen King novel...
Next is a compression test... While yer at Harbor freight, get you one.
You couldnt be any more vague.
We need details
Is this truck a V6, a 4 cylinder?
Auto?
Manual?
4wd?
2wd?
We cant help you unless you give us these details.
Sorry if i'm rude, but, this is as bad as saying
"Truck dont start, what do?"
zd92655
03-06-2022 12:58 PM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
