1988 yota pickup driveshaft
Old 05-11-2013, 05:38 AM
vynilmikings's Avatar
i have an 88 toyota pickup, with the 22re, standard cab short bed. 5 speed.
just got this the other day, and realized the rear driveshaft is dented and bound to fail. i called the local shops and they concluded that it would be $200+ to repair it.
so im looking for a new or used one. but new onnline they are looking to be 300-400. i found one at a junk yard for $65, but it is from a 1991 pickup, standard cab, 22re 5 speed.
will the drive shaft from the 91, fit my 88??
i appreciate the help in advance!
Old 05-11-2013, 06:46 AM
bone collector's Avatar
they should be the same but the only way to be sure is to measure it
Old 05-11-2013, 06:49 AM
MudHippy's Avatar
They should. If everything else is the same. Needs to be from a 4WD or 2WD(whichever yours is) with the same transmission(W-series or G-series).
Old 05-11-2013, 06:51 AM
Stetson_md's Avatar
Ya I think it will work here's some more though if it won't http://www.car-part.com/cgi-bin/search.cgi
Old 05-11-2013, 06:58 AM
Dang, yea its a 2wd at the yard.
Old 05-11-2013, 12:16 PM
Stetson_md's Avatar
The link I posted is for 4wds theres a couple for 75 on there
Old 05-11-2013, 04:05 PM
that link didnt work. ill search through the site and see what i can find
Old 05-13-2013, 06:21 AM
Stetson_md's Avatar
Well I did a search for a 88 reg swb 4cy ,toyota ,truck (except t100 and Tacoma), driveshaft rear, in ohio. If that helps you find what i was talking about,I think I wrote it the same as it is on the site.
There where about 10 that came up from $75 -$125 and to get one you'd have to call the junkyard its at
Regency
20
01-03-2020 07:43 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: 1988 yota pickup driveshaft
