Exhaust: TRD vs Borla
Old Jun 7, 2006 | 05:05 PM
Mikestang's Avatar
I just got the 4Runner in my sig and want to do an exhaust immediately. I'm looking at both the TRD and Borla setups, and while they're both pricey, I like what I see. Does anyone have any pictures and/or experience with these systems, or any recommendations on another system? Thanks.
Old Jun 7, 2006 | 06:34 PM
fiveofeen's Avatar
glad to see you found the place... I should get a referral fee!
I am a fan of borla, I'll see if I can find a sound clip...
http://www.demello-offroad.com a member here works there check it out. They offer some of the other parts you are looking for.
I couldnt find much from a search, it seems you got JBA, Magnaflow, Borla, & TRD to choose from.
Old Jun 7, 2006 | 09:58 PM
humanoid's Avatar
I thought Borla made the exhaust setup for TRD?
Old Jun 8, 2006 | 03:33 AM
Koz's Avatar
Koz
You may want to also look at the Magnaflow system, it is a much better bang for the buck (less then $400), with the same quality.
Koz
Old Jun 8, 2006 | 06:27 PM
Mikestang's Avatar
Thank for the info so far, I'll do some looking, too.
Old Jun 11, 2006 | 04:58 PM
Elton's Avatar
i would save my self some cash and have one made
Old Jun 11, 2006 | 07:31 PM
mkool's Avatar
Humm...I read somewhere that V8 4runner, if you put magnaflow catback system...there is annoying drone problem....I also interested in buying magnaflow system but I'm waiting for someone that bring some trick or solution.
Old Jun 11, 2006 | 11:21 PM
HUTCHSTACO's Avatar
i love magnaflow, great quality, my friend is one his second flowmaster while my magnaflow still blings under my truck, polished stainless steel
Old Jun 12, 2006 | 07:50 AM
Koz's Avatar
Koz
I don't have the drone but some have complained. I wonder if it is just they are not used to the louder exhaust.
Koz
Old Jun 12, 2006 | 10:27 AM
Mikestang's Avatar
From the picts I've found the TRD system is a dual outlet, one behind each rear wheel. The magnaflow system looks nice, too, with a dual outlet on the passenger side.
Does the TRD system reduce ground clearance, or hit the spare tire, or anything like that? It would seem to me, at first glance, that the dual outlet out one side is a better design, but then I can't think Toyota would design a system for their own vehicle that wouldn't work just right.
Old Jun 12, 2006 | 03:49 PM
Mikestang's Avatar
Pulled the trigger on the Magnaflow system since it cost 1/2 what the TRD system did (got it for $380 locally). Bought a cat-back for the wife's F-150 with the money I saved! I'll post some picts after I install it this weekend.
Old Jun 13, 2006 | 03:37 AM
Koz's Avatar
Koz
You going to love it!
http://www.toyota-4runner.org/showth...w&pagenumber=3
Koz
Old Jun 13, 2006 | 07:36 PM
mkool's Avatar
Koz, I used to can write a thread and reply....I don't know why...I'm blocked there so I can't ask anything...I have same nick name over there...
Anyway...Can't remember which thread but I watched someone's video about his magnaflow and supercharger. after he turned corner and as he speed up I hear loud muff sound from video clip...can you remember which one I'm talking about???
question are ;
1. has anyone drove break-in period? what's sound like?
2. Like in video clip...is really that much loud, hearing from inside?
3. Magnaflow, for 06' V8 4runner, is it only comes size of 24"? ( I may pay visit to their website, I guess).
4. after installed magnaflow cat-back system, how do you keep your original system?
Thx for read and anwser my questions.
Old Jun 13, 2006 | 08:32 PM
Mikestang's Avatar
2. An aftermarket exhaust will always be louder because it's less restrictive. It will be quieter in the car than outside, but it's still louder. I have a 440 (flywheel) horsepower mustang, so I know all about loud interiors...
3. If you talk with a magnaflow dealer I'm sure they can work out whatever size muff you need.
4. Not sure I understand this, as the point of the cat back is to replace that portion of the stock system. You keep everything forward of the flange connection after the last cat. The rest goes to the recycler.
Old Jun 13, 2006 | 08:36 PM
Elton's Avatar
so im guessing a custom cat back is no good..... i would like to spend the money saved else where
Old Jun 14, 2006 | 05:48 AM
Koz's Avatar
Koz
question are ;
1. Do you mean, with a cat-back system? A cat-back system will not interfere or cause any problems with the break-in period. Any system with fiberglass packing will get louder in time. Mine has changed very little if any.
2. The Magnaflow system is middle of the road as far as loudness. JAOS is on the quiet end and Borla + TRD would be more towards the louder end. The more back-pressure (quieter) systems will provide less HP gain. The less back-pressure (louder) systems will provide more gain.
3. The Magnaflow cat-back system (for the V8 +V6) comes with a 24" muffler. I think the confusion is that some owners are measuring the muffler body only (which is 18") and 24" from end to end.
4. I hung mine up in the garage with a rag stuffed up both ends. The OEM system is stainless (not sure about muffler) also but it still will rust.
Koz
Old Jun 15, 2006 | 06:01 PM
RapidRunner's Avatar
This is a good question, and from the pictures, the answer isn't obvious. But, the answer is, if you care about clearance or are planning to do some off-roading, the TRD dual outlet exhaust is a joke. The "dual outlet" really just splits off and rerouts a longer path around to the driver's side. This extra pipe hangs down lower than the rear differential and is just beggin' to get whacked. I have a photo somewhere -- I should try to find it.
I was actually pleased with the TRD dual exhaust on my Tundra, so I ordered the TRD for my '03 4Runner -- I ordred it when I bought the vehicle and even had the dealer install it. BIG WASTE OF MONEY. I ended up taking this expensive exhaust to an exhaust shop and having them change it. I had them convert to a single outlet just behind the passenger rear wheel (just like the Magnaflow -- except one big tip instead of 2 smaller ones) -- anyway, that preserved the sound, eliminated the clearance problem -- and here's the biggy: it completely eliminated the annoying drone I got between about 1800 and 2200 rpms. The end result I really liked, but it cost way too much money. (I actually had them make it so that I could unbolt the custom piece and reinstall the TRD pieces from the muffler back).
Well, I traded in that vehicle for an '05. For the new 4Runner I just got the Magnaflow. I ordered it online and will install it myself (haven't gotten around to it yet). But, for about 1/3 the price I'm pretty sure this is the way to go -- and, it gives me the improved clearance rather than messing it up like the TRD dual does.
Now I really can't speak directly for the Borla, but my understanding is that it's about the same as the TRD. If you don't care about clearance then either the TRD or Borla is probably ok, but since you asked -- I'd go with Magnaflow.
Old Jul 14, 2006 | 10:11 AM
DBS311's Avatar
Elton, you could spend money on a "custom" cat-back but to beat the price of the Magnaflow, it will be crunch bent instead of mandrel, and probably not stainless as well. You end up spending money for something that will probably be worse than stock, only louder. If you spend any money on an exhaust, spend the extra it takes for mandrel bent stainless steel.
Steven.m.paulk
Jun 7, 2020 10:45 AM
White Stripe
Oct 6, 2015 10:47 AM
LCE_Performance
Oct 1, 2015 01:03 PM
4runnerFireman
Sep 29, 2015 06:24 AM
83
Sep 27, 2015 04:13 PM
