What in the world is this for?
Under my passenger side dash
It doesnt seem to affect anything when i turn ir up or down
I was actually looking for a rattling sound from behind the glove box and found this. Still haven't figured it out but having a friend help while I drive to find it.
I think he wants to know what the "RPM" control is for.
Not quite. The idle is raised by the A/C idle-up VSV, which is just switched with the A/C compressor clutch. The A/C amplifier has no way to control "how much" the idle is raised; that's just a function of air bypassing the throttle valve.
Instead, the RPM control on the A/C amplifier sets the RPM below which the A/C Compressor will not switch on. If the idle-up isn't enough (under whatever conditions exist), the compressor clutch opens to stop from stalling the engine.
I don't know of a formal procedure for setting that control, and it's hard for me to imagine what it would be. So for me, I don't mess with it.
Besides the A/C idle up valve, there is also the A/C Amplifier (behind the glove box) that has an adjustment knob to set the low idle RPM cutoff point. So if either of those are out of adjustment or not working right, the A/C will cut out at idle. So make sure the idle up valve is working and does bump the idle speed up 100 RPM or so with the A/C on (white knob adjusts the idle speed). And make sure the low RPM cutout is a little below the normal idle speed.
If the rattle youre chasing is a metallic sound, check your door check on that side. Mine rattles at times, opening the pass. side door all the way and closing is stops it.
AC amplifier adjustment is specified somewhere but I'm lazy today. Cranking speed is 250-350, on an automatic transmission the in gear idle is 550+ set your cutoff in the range of 450-500. And it should be near to factory specs.
Good call on the door stop, there is a little brass roll pin and easy to distort. Think one of mine is replaced with random small nail now that I think about it.
Another random bit that would be hard to locate would be the antenna mount between the inner and outer fenders.
a
a
mbomberz1
02-15-2017 08:53 PM
